Building a M19 Tank Transporter
United StatesJoined: October 14, 2012
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Wednesday, July 29, 2020 - 07:05 AM UTC
California,
United StatesJoined: February 01, 2010
KitMaker: 551 posts
Armorama: 543 posts
Posted: Wednesday, July 29, 2020 - 08:58 AM UTC
Watching this one. Very curious to see how this kit turns out. I was not aware of it either which only heightens the interest!
Armed Forces Europe,
United StatesJoined: December 27, 2015
KitMaker: 290 posts
Armorama: 249 posts
Posted: Wednesday, July 29, 2020 - 12:07 PM UTC
I have both the hard top and the soft top versions! Will be following your Build.
Pennsylvania,
United StatesJoined: January 18, 2003
KitMaker: 2,402 posts
Armorama: 2,377 posts
Posted: Thursday, July 30, 2020 - 04:10 AM UTC
Donald, you should ask the Admins to change the thread title to M19 so it can be found more easily on searches.
KL
Posted: Thursday, July 30, 2020 - 04:40 AM UTC
KL
Hey Administrator can you change the thread title.I don't know where I got the T from.
I'm getting senile in my young age of 73.
Thank you.
Donald
Posted: Thursday, July 30, 2020 - 04:42 AM UTC
Posted: Thursday, July 30, 2020 - 04:47 AM UTC
Now I remember why I don't do TRUCKS.
Very Frustrated.
Donald
Removed by original poster on 07/30/20 - 18:52:24 (GMT).
California,
United StatesJoined: January 16, 2014
KitMaker: 23 posts
Armorama: 22 posts
Posted: Thursday, July 30, 2020 - 06:52 AM UTC
[Donald,
A great pick. I will follow along as I have this to build.
John
Florida,
United StatesJoined: May 16, 2002
Posted: Thursday, July 30, 2020 - 10:14 AM UTC
It looks the gearbox is backwards (180 degrees out) on the inner (right side) axle in the below pic. I believe both gearboxes should face the same direction. This would align all the drive shafts.
Field Artillery --- The KING of BATTLE!!!
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
Showcase
Posted: Thursday, July 30, 2020 - 12:38 PM UTC
As pictured is exactly how it is on the Instruction sheet, I think it's kind of strange way of doing things.
In all the trucks that I've seen the drive shafts are alighned.
I don't have a Pic of the real thing so I go with the instructions.
Here's a Pic. of the instructions.
Regards.
Donald
Florida,
Posted: Thursday, July 30, 2020 - 12:44 PM UTC
I don't think the whole axle is backwards. I think it is just the triangle-shaped gearbox on the top side of the axle that is turned around. I could be wrong, but that is how I see it. I would turn the gearbox 180 degrees to fix it.
Showcase
Posted: Thursday, July 30, 2020 - 12:52 PM UTC
It wouldn't fit, The drive shafts would be too long and they are angled on the ends to fit this way.
I wonder if anyone has a picture of them?
Donald
Each Axle is identical except for the plug in the rear of the final one.
#084
Quebec,
CanadaJoined: September 14, 2005
KitMaker: 2,485 posts
Armorama: 743 posts
Posted: Thursday, July 30, 2020 - 12:58 PM UTC
Donald, Look here at the real thing on 2nd page...click to enlarge
and control plus to magnify.
https://www.tankograd.com/cms/website.php?id=/en/Tank-Transporter-M19.htmCheers,
Florida,
Posted: Thursday, July 30, 2020 - 01:14 PM UTC
Apparently that is how they were on the actual vehicle. Strange.
Showcase
Posted: Thursday, July 30, 2020 - 09:16 PM UTC
Thank You very much.
It looks like I have it assembled correctly.
The fit is very tight and tricky to do.
Regards.
Donald
Posted: Friday, July 31, 2020 - 07:48 AM UTC
Posted: Friday, July 31, 2020 - 07:53 AM UTC
Posted: Saturday, August 01, 2020 - 08:07 AM UTC
Today I'll be installing the Pe. running boards, Fuel tanks & storage boxes.
The running boards are Pe. and need a rounded edge on the outside edge. Here's how I did that.
Using my Pe. bender and a thin brass rod to give the edge.
Place rod on thinner area and bend up over the rod.
Posted: Saturday, August 01, 2020 - 08:12 AM UTC
Posted: Saturday, August 01, 2020 - 08:20 AM UTC
Don't bother with the seams on the fuel tanks as they will be covered and not visible .
The fuel tanks & tool boxes get tread plates on top .
Next, painting it all.
Donald
Colorado,
United StatesJoined: February 24, 2014
KitMaker: 3,033 posts
Armorama: 2,492 posts
Posted: Saturday, August 01, 2020 - 09:47 AM UTC
I really enjoy following this build. Thank’s for sharing! 🚛
—mike
Posted: Monday, August 03, 2020 - 07:22 AM UTC
Today it's the Wench that is Winch
I painted the frame, man I know I screwed up, I should have painted it before putting it all together.
Here's the winch assembled, If I wanted to describe in detail building it, it would take a whole chapter.
The main thing to look out for is the 2 little holes where the control rods go , they need to be drilled out a little and they go toward the control handles on the end of the wench.
Posted: Monday, August 03, 2020 - 07:31 AM UTC
You will have to enlarge the 4 openings on the bottom of the winch to fit it to the frame.
The Drive Shaft is offset slightly.
When test fitting or installing the winch, install the drive shaft loosly then slip the winch forward engaging the shaft and mounts.
Posted: Monday, August 03, 2020 - 07:40 AM UTC
