Hosted by Jim Starkweather
Do I need a specific Airbrush?
flatfour
KitMaker: 21 posts
Armorama: 11 posts
KitMaker: 21 posts
Armorama: 11 posts
Posted: Tuesday, October 27, 2020 - 12:47 AM UTC
Hi, I purchased an Iwata HP-CS airbrush and have been so impressed, not only with what the AB can do but, also how it has enabled me to achieve such fantastic results after a very short time, as a newcomer to the technique. However after using my AB to apply base colours to my models, I wanted to apply camouflage. The results I have achieved so far are 'adequate' , at best and I have become frustrated at not being able to get fine, almost speckled appearance. Sorry to have taken so long to get to my question but, Do I need a second AB that will give me really fine results that are in scale with the rest of the model? I have reduced the pressure and made my paint thinner as advised. Can I simply use a small needle and nozzle jet in my existing AB? Thanks in advance for any help. Watto.
varanusk
KitMaker: 1,288 posts
Armorama: 942 posts
Armorama: 942 posts
Posted: Tuesday, October 27, 2020 - 12:57 AM UTC
You have an excellent tool and should not need a second one, it is just a matter of practice.
Play with pressure, dilution, how far you pull the trigger back and distance to target... For thin lines you need to be very close to the model and spray little paint (trigger not full backwards).
The rear lock is very useful, you can screw it in completely and start airbrushing on a paper -no paint will be sprayed. Then at the same time, unscrew it until paint comes off so you can leave it there to continue on the model. Hope I have been able to explain it...
In any case, you may already know that for hard edge camo, there is no other way than masking.
Hope to see you on the new forum next time
flatfour
KitMaker: 21 posts
Armorama: 11 posts
KitMaker: 21 posts
Armorama: 11 posts
Posted: Tuesday, October 27, 2020 - 06:06 AM UTC
Thanks very much for your prompt reply, I will listen to your advice and practice my skills. I am finding the forums very useful.
One day I'll be brave enough to show my work.
Posted: Tuesday, October 27, 2020 - 06:44 AM UTC
You should consider signing up for the new forum since this will be closing down due to technical reasons in the not too distant future.
You can find the new forums here
https://forums.kitmaker.net/
The look and feel is different.
The sign-up process includes responding to an activation e-mail. This e-mail can go missing(e-mail services/providers hating each other).
I monitor all new accounts to catch and activate those that get stuck due to lost e-mails.
See you on the other side.
Posted: Tuesday, October 27, 2020 - 05:34 PM UTC
Here's a video with tips on how use your airbrush, shows how to make fine lines and what not.
https://www.youtube.com/watch?v=Xp2EUMwL5Tw
flatfour
KitMaker: 21 posts
Armorama: 11 posts
KitMaker: 21 posts
Armorama: 11 posts
Posted: Wednesday, October 28, 2020 - 12:30 AM UTC
Just done it, thank you very much.
flatfour
KitMaker: 21 posts
Armorama: 11 posts
KitMaker: 21 posts
Armorama: 11 posts
Posted: Wednesday, October 28, 2020 - 12:32 AM UTC
Nice one, thank you. I'll have a look. Watto.
