General Ship Modeling: Super-detailing
Topics on photo-etch, metal-parts, and all types of additional detailing.
How to make a 1/700 life saver?
redneck
KitMaker: 1,602 posts
Armorama: 384 posts
Posted: Sunday, December 10, 2006 - 05:04 AM UTC
I’m going to need about 4 1/700 life savers.
Does anyone have any idea how to make them?
#027
Louisiana, United States
KitMaker: 5,422 posts
Armorama: 25 posts
Posted: Sunday, December 10, 2006 - 05:48 AM UTC
Try very small plastic tubing.
Gator
Gunny
KitMaker: 6,705 posts
Armorama: 713 posts
Posted: Sunday, December 10, 2006 - 03:29 PM UTC
1/700 life preservers?
Jeez, Jacob, your going to need some good eyes to pull this one off!!
1/35, no problem, but 1/700?. . .ideally, these would be tiny molded resin or plastic pieces, not a photo-etch part. Sorry mate, I'm no help at all on this one. . .
~Gunny
redneck
Armorama: 384 posts
Posted: Sunday, December 10, 2006 - 05:55 PM UTC
Thanks Guys.
Kenny the tubing idea sounds good. I wonder if one of those straws for spray cans would be the right size?
Mark I did a search over on greatmodels and could only find them as PE. I also figured they would be to flat to do the job.
skipper
Lisboa, Portugal
KitMaker: 5,182 posts
Armorama: 761 posts
Posted: Monday, December 11, 2006 - 04:15 AM UTC
Hi Jacob
Those tubes that you mention are more or less the right size (a little bit over, but acceptable) but in the wrong plastic.
You can try to make a lenght of streched sprue of the right thikness, wrap it around in a wire (being the section of the wire the size of the hole of the life buoy/life preserver) and put it for about ten seconds on boiling water.
Do not thouch it until is gets cold!
When it is cold, remove the wire from the plastic coil, cut circles (section of the coil), put a dab of glue on the ends of the new section and you have your life buoy - just needed to be painted.
It's easy, cheap and you'll get all the life buoys you need - with a space for mistake
Hope this helps,
Skipper
redneck
Armorama: 384 posts
Posted: Monday, December 11, 2006 - 05:16 AM UTC
Thanks Rui.
I’ll give it a try.
